I've been tearing into several carbs I have had around and I found that on has a brass float and the other a plastic. This is for a 77 and 78 quadrajet with out eletric choke. What is prefered? Can I swap floats?
)-I'd assume the 17057213 and 17058213 use the same float too--but I'll check again in my book (it out in my shop!)..and get back to ya..might not be until later tonight or tomorrow before I go back to the shop though..
diesel4me said:I wrote your # down wrong!--but 17057215 and 17058215 are the same float-(I wrote down a "5" instead of a "3"!)-I'd assume the 17057213 and 17058213 use the same float too--but I'll check again in my book (it out in my shop!)..and get back to ya..might not be until later tonight or tomorrow before I go back to the shop though..
Actually,only 2 # of floats fit 90% of all Q-jets..and they look very different..but its best to use what the book says,just in case..![]()
--I forgot to look up your info!--I'll look tonite and post back ASAP--might be tomorrow before I can get online again..sorry !!..I'll get you the Standard/Hygrade brand part # and also the # for a carb kit and choke pull off,and accelerator pump..
