what type of piston rings, and cylinder prep has it had?...that makes a difference in breakin procedure.
Do NOT use synthetic oil for break in, rather a quality 10-30 or 10-40, with your cam and rockers you don't need a break in lube, just good assembly lube when it was put together.
Bearings don't care as long as they are assembled with assembly lube.
Roller cam don't care as long as rpm is sufficient to provide splash lubrication on the cam, and lifters. It should have a coating of assembly lube when assembled.
Prime engine, turning it over a few revolutions while priming, make sure you have good oil pressure.
Set your #1 timing to fire straight up or a few degrees advance, and try to get carb set right before trying to fire....run the rpm up to 2K or so until the engine has reached operating temp. This is needed to provide pistons, rings and cylinders with lubrication.
Run it for 5 min after reaching operating (175-200) then let it idle and set timing and carb properly. All this time you should be looking for leaks or anything that doesn't sound or look right.
A roller cam doesn't need a break in period, rings might depending on what type they are. Moly will seat pretty quickly, and a few miles of regular driving will do that, Iron rings will take longer, never used the run the piss out of it right out of the gate theory, but race engines do that all the time!
