Break-in procedure / 1st motor start
I hope you have a chip for this thing because that TBI computer isnt gonna know wtf to do with a stock tune with a 383.
Yah, I just rebuilt the 383cid that I already had in it. I do my own tunes and had it running pretty good. I am not a great tunner by any means, but have fun doing it.
O Ok I just wanted to make sure you weren't gonna wash your damn rings breaking the thing in :waytogo:
Looks like that one has the plug/grove deal to get oil everywere.
It will take awhile.
Just dont prime it with no oil pressure sender and ur face over the dist.:whistle: Oh the memories of being 17 and green:doah::haha: might have to add that to the what not to do thread
I forgot to update this:
After warming the oilpan a bit (big shop light under the pan) the motor primed with oil dribbling out the pushrods. It fired right up and ran great. Thanks for all the advise here.
I do seem to have a small oil leak at the rear of the motor. I am tring to determine if it is a rear seal, oil pan, or top-end leak.
I just found this on the Pace Performance web-site:
GM Recommended Crate Engine Start-Up Procedure
1. SAFETY FIRST! If the car is on the ground, be sure the emergency brake is set, the
wheels are chocked, and the transmission cannot fall into gear.
2. Be sure to check the oil level in the engine and prime the oil system with an engine
priming tool! This is the most important step! Your crate engine has most likely sat for a
while and most of it's lubrication has drained back to the pan!
3. Quality 10W-30 or 10W-40 Oil is recommended for GM's Performance Crate Engines.
Most Stock Factory replacement engines use either 5W-30 or 10W-30 oil. If you plan on
running synthetic oils, we recommend that a new engine is first broken in with regular
mineral type engine oil.
4. Adjust the distributor timing roughly by hand for quick start up and smoothest idle
possible.
5. Set the ignition timing after engine starts.- Starting point for most carbureted crate
engines is 10 degrees Before top dead center with vacuum advance disconnected.
Computer controlled engines with a distributor are generally set at 0 degrees before top
dead center with the set timing connector disconnected (refer to your vehicles service
manual for details)
6. Flat tappet hydraulic cams only- (Such as the 250 hp-350, 290hp-350 & 330hp-350
Run the engine between 2,000 and 2,500 RPM's, with no-load on the engine for the first
30 minutes. This is critical to break in the camshaft.
7. Roller Cammed engines (such as the ZZ4, F.B. 385, 383's and big blocks) do not need
to follow the procedure in step 6 because roller cams do not need to be broken in.
8. Remember that the cooling system on a fresh engine swap will have a lot of trapped
air, which will lead to wild temperature gauge readings and possible water pump
cavitation (water pump not moving coolant due to trapped air) To help avoid trapped air
in the cooling system, try to fill the cooling system up with a 50/50 mix of quality coolant
and water a few hours before you plan on starting the engine. Leave the radiator cap off
during this time. This will tend to help purge a fair amount of trapped air before you start
the engine. Specialty fill funnels can also be purchased from Listle tools and Snap-On
dealers that help alleviate this problem. Also helpful during break-in is to use a Lever-
Vent type radiator cap on your radiator in so that you can manually purge trapped air
while engine is running- (use extreme caution to avoid being burned by hot coolant) Your
normal cap can then be re-installed after engine cools off.
9. Drive the vehicle with varying speeds and loads on the engine for the first 30 miles. Be
sure not to use a lot of throttle or high RPM.
The following 2 steps generally are not necessary due to our advanced piston ring sealing
technology, but can be performed to help ring break in.
10. Run five or six medium-throttle accelerations to about 3000 RPM (40 to 50 MPH),
then letting off in gear and coasting back down to 20 MPH.
11. Run a couple hard throttle accelerations up to about 5000 RPM (55 to 60 MPH), then
12. Let engine cool and change the oil and filter and check coolant level, top off if
necessary.
13. Drive the next 500 miles normally, without high RPM's (below 5000 RPM), hard use,
or extended periods of high loading. 14. Change the oil and oil filter again.- Keep an eye
on oil level during the first thousand or so miles. 15. Your engine is now ready for many
happy cruising miles!
I prime it... start it ..... pull it out in front of the house.... rev it to 6500 RPM and side step the clutch...
If its gonna break....... I want to be close to home....:D
I do the run the piss out of it theory :pimp:
After one normal initial drive
did anyone mention temp gun? watch those cylinder heads close to make sure everything is at the correct operating temp before you go driving anywhere.
