In the last year I have twice broken the upper shock mount on the driver side rear. I haven't repaired the second break yet. The first repair did not fail, it was the original metal that failed. The left rear (it mounts to a hole in the frame) has also been crakced and subsequently repaired.
Anyone else had similar problems? What did you do to make a permanent repair or upgrade? I have been thinking about DIY's cross member mount but want to know of other options first.
By the way, the first breka occured with the 4" lift and shocks and the second failure happened with the 6" lift and appropriate shocks.
