THEMCGUIRE
Hello all... Hope you all have a wonderful holiday.
So here I am in North NJ and the weather is so warm. Decided to try and finally fix the breaks now that the trans has been rebuilt to level 1 upgrades. $2200.00 with a 3 year warranty.
While the truck will stop, the break pedal is on the floor when it does. It takes a while to stop, you cannot stop on a manhole let alone a dime.
I tried bleeding and I broke the bleeder on my front caliper. So I bought new calipers. Bled the breaks with engine off they were tight. Started engine and they went to the floor.
The trans guy suggested that it was the master cylinder. Replaced that. Bench bleeding is a bitch without a vise.
Re-bled the breaks with engine off, they got tight. Started engine they went right to the floor.
I do not see any break fluid on the ground under the truck.
(A lot around the outside where I spilled it when the slippery bottle slipped out of my hand. lol)
Per the shop manual I bled passenger rear, driver rear, passenger front and finally driver front.
Any ideas ?
Any ideas ?
You'll also want to check to make sure your wheel cylinders aren't leaking and that everything is connected properly.
