I have a Craftsman Professional (?) unit that broke a rod.
Cheapas s stuff right here.
I bought this thing about 10 years ago, paid about 500$ for it, but have used it quite a bit. It broke one rod and that took out the fan, and the tin cylinder in which the piston travels. The piston has some type of fiber/teflon? sealing disc on top of it, held in place by a tin plate with a screw in it. Top notch stuff????
I replaced both piston/rod/cylinder assemblies, and the fan, and the spacer washers between the crankpin, and the 2 rods. Simple stuff.
The replacement parts were about 110$ to my door in 3 days, and it took about an hour to put back together.
I'm so happy to have air again.
The compressor:
The carnage:
Tore down for inspection:
The crank counterweight and crankpin were both tight still, just replaced the spacer washer on the crankpin:
Ready to run:
The compressor:
The carnage:
Ready to run:
