handloader90
Building!
Trying to pull the axle shafts on a 12 bolt.
Axle is sitting in the bed of my truck.
Started backing the cross pin retaining bolt out of the carrier, came out easy enough but it snapped off where the bolt necks down and turns into a smooth pin.
I believe there may be one thread left on the part of the bolt that is stuck in the carrier.
I used an extremely strong magnet to see if it would pull it out and that didn't work, tried to see if I could catch a pick on a possible burr and turn it out that way... didn't work either.
I commenced to smashing the cross pin with a large punch and sledge hammer in hopes that it would break that bolt all to sh*t and then I would be able to take the broken bits out after the cross pin was out.
Truck is located in a gravel parking lot, no electricity around, can't move the axle or the truck. So hand tools only.
Should I just keep banging on this thing? Seems like that bolt would give at some point.
I have a fresh crosspin and retainer bolt to install afterwards so damage to the cross pin is not an issue.
...drove it a few more years and had no issues,but my brain was always waiting for that "Bang-screech" noise,when the carrier broke the rest of the way and locked up the rear wheels..never did though!..
