#2, #4, #6, and #8 pistons (driver's side) are broken on a fairly freshly built Cadillac 500. Like 700 miles and 18 hours.
Other side of the motor looks like brand new. Like only 3% leakdown with cold cylinders.
All of the non-broken rings I've checked have been spot on. Same for the bores.
I don't have the tools to measure the deck height for precision or accuracy. The pushrods are the same length but that doesn't mean much. I did measure the heads and they're within half a CC across all chambers between each head (they're the common 76cc heads). I was wondering if that side had a higher compression ratio from milling (I know one head is missing .015") but I calculated that in order for it to make a difference on a motor that size it'd have to be a lot of missing material.
It pretty much always had blowby (enough where the PCV valve couldn't keep up since day 1) but I was told it was because the rings hadn't seated but seemed strange to me. 10-15% leakdown depending on cylinder (#4 and #6 the worst) at hour 4. I never did check it for leakdown again as all plugs looked good and it's a PITA to check anything with the wheel liners in. I did scope it at hour 4 with a camera and the pistons still were fairly clean. Driver's side was worse but I didn't think much of it as that's the side that the PCV valve connects to.
First motor I paid someone else to assemble and I regret it now. Anyway, I kept running it. Blowby never got better. It was also better when the engine was cold than warm.
Crazy part is that it still ran fine right up to when it started pushing all the oil out the front of the motor due to so much blowby. Limped it 200 miles home pissing out a quart of engine oil every 15 miles didn't help the bearings any but it still held 40psi at idle but basically only stopped when the lifters didn't keep the valves open. Leakdown when I got it home was 80%.
I did have spark knock for a brief period (Davis Unified Ignition/DUI sent me a garbage distributor with 40 degrees of advance that went to 16 degrees of advance at idle and 40 by 3100rpm). Never seen all the pistons on only *one* side of the motor go from detonation. There is no pitting in the crowns or any cracks. Most of them aren't even broken between the two compression rings. It is always on the front of the piston below the oil control rings.
Dual plane intake so if it was running lean on one side (TBI motor) it should have taken out two pistons on each side of the motor. The side that ate itself is the side with the oxygen sensor.
If any of the pistons weren't all on the same side or all of the pistons on one side weren't broken I wouldn't have questioned it.
Ideas?
Ideas?
