Then it is much easier. Weld that bad boy upSteel housing.
Thanks I’m taking it to a shop tomorrow because I’m trash at weldingThen it is much easier. Weld that bad boy up
Thanks !At this point I would ditch the 2nd shock, cut the mount off and reweld a new mount on.
What shock should I keep the inner one or the outer one ?That entire Mount needs to come off and a new mount welded on. Steel to cast iron (pretty sure that is what your axle is made from) is a different process. I am pretty sure (someone correct me if wrong) the cast iron needs be be pre-heated before the steel Mount can be welded. If you are not comfortable welding, I am sure a local shop can do it for you....I'd do both sides just to be safe. Ditch the dual shocks and get a good single setup.
I believe your outer shock is in the same position as single shock setups. If you are planning to have the shop weld in on I would recommend getting a prefab Mount so they don't have to make one for you. There are many sources out there.What shock should I keep the inner one or the outer one ?
Why run two shocks?
Those should MORE than work!!I just got these in today so I can get them welded in tomorrow. I think these should work.
