sixb
I have no brake lights and gonna remove the harness for the front clip so no head lights, running lights or blinkers. I'm gonna remove the heater, I only have dummy lights in my cucv and gonna switch to 12 volt system which makes the 24 voltmeter useless. The only gauges I need are volt meter, oil pressure and water temp. I'll probably put a egt and boost gauge in it for trouble shooting when I turbo charge it. So should I completely pull all the wiring and start over with the bare minimum?? I'll need power for the gauges some after market lights, Also need to run a few wires for the 6.2 diesel but not many really. Switch to manual glow plug system and starter and alternator wiring. There's probably more but you get the point and I know nothing about wiring at all
Here is a pic of what I have and another of what I'm kind shooting for on the front at least.
So what would you do splice into the existing harness and make it work.
Build your own harness.
Find a company that specializes in this stuff to build a custom harness for me.
Here is mine.
Here is one I found on the web I like and will build the front to mimic.
Here is mine.
Which I'm proud to say it doesn't.
because the 12 volt conversion must happen plus I got to redo the motor mounts, fix a broken starter bolt, obtain and wire in an electric fan, swap out my cracked tranny case, fab up another t-case cross member and switch to a smaller aluminum radiator that I already have oh and install a winch.
