you add in brakes and bearings on the 60 but not on the 44
apples to oranges
I am on my second d60, I am into it for less then $2000cdn
1981 d60 and matching 14ff with 4.10 $1000cdn.
average deal here bought the first one I saw in the first week I looked.
replaced spindles, bearings, rebuilt kingpins, did brakes for another $1000ish
yes I still have to do the lockers, but most people will not change out the spindles at $150usd each like I chose to.
1981 was fat axles so you really have to get an oldy to see the neckdowns
even if you had neckdowns they are not a "must change" item, run em until they cause you grief
new shafts are not very pricey IMO
if the tire size is under 35" then a 44 is all you need
I would not spend any $ on aftermarket beef parts on one unless you were racing and needed to be light
light is $$
