IL built 1991 K5 needs finished or parted
nwcustoms
Registered Member
Chicago
Hey there, i have a 1991 k5 with 93,000 on the clock. truck runs good, no drivetrain issues, then rusty rockers came in and I pulled the body apart to repair it, and lost intrest and need to buy a house. here is what i have done, most of which have less than 500 miles on it. (built the axles, then rust did it in shortly after.) 12k winch, sye on transfer case, rear is ff 14bolt, with disc brake conversion, detroit locker, and 4:88 gears one ton drive shaft. love the combo with overdrive 4l60. front is ten bolt coverted to 8 lug, 4:88 gears, crossover steering, heavy duty tie rod, heavy duty steering arms on both sides, ready for high steer, steering box brace, no frame cracks lift is 4inch springs with ORD shackle flip in rear and heavy duty shackles up front. zero rates all around Wheels are 16x10 micky thompson classic II with new 35inch PITBULL ROCKERS black with red interior, rear window works, has ac and power windows. I need the whole truck gone. does not drive due to body is separated from frame by 6 inches so I can clean the frame. Located 30 min south of chicago. just tired of dealing with rust on frame and rockers. $5,000
thanks for reading, Jerry, 8155872284, text me and I can send pics
http://chicago.craigslist.org/sox/cto/5039298986.html
