Shawns84
Registered Member
Hey,
Just installed some 6 inch tuff country ezride fronts with a one inch add a leaf installed in the center hole. Ride awesome compared to the pro comps. BUT the bump steer is horrible. I have the skyjacker dropped pitman arm, and the pro comp raised steering arm. The drag link is almost level with the ground, maybe about 3-4 degrees downward from the steering box.
I did some searching and most of my findings were "go to crossover steering" and maybe possibly there is a better drag link angle that i could try. Im considering x-over as a resort after i have tried everything with the stock steering and im still not happy with it. Are there any things i can try with the drag link? Another thing i have noticed is when the truck isnt moving and i turn the wheel the springs move about 5/8s of an inch forward and backward due to flex. Is there anything i can do to stop this like some kind of a forward/reverse axle support?
To try to bandaid the problem so far i have adjusted my shocks all the way stiff and connected the sway bar. Both helped slightly.
Any more suggestions? The whole reason im hesitant with x-over is cause i cant get any good deals on parts through ord, and i dont know of any other reputable companies that sell a x-over setup that i can obtain without markup through about 2-3 different places.
Anyways, all comments welcome, thanks in advance.
Shawn
Shawn
