Burb getting 33x10.5x15 BFgoodrich Mud Terrains
82TexasBurban
Texas
Finally have gotten a chance to get the tires....I am running 10 bolt rear so decided to get the narrower tire. But could not help but get the mud terrain it looked so good. I saw great reviews and I finally got her in good running order. They are on there way to the tire shop and should be on this weekend. Replacing 9 year old 32 inch winston winners....which i have to say other than the shimmy have still have plenty of tread left! Wanted to get to do some realy wheeling and these should let me do a bit more.
I love my 35x12.5x15 BFG all terrains. They wear like iron even with my rig locked on both ends and look sexy on my stock rallies. Quite on the street and work well even in the dirt if i air them down.
I know its a little different tire but I love the KM2s i have on my DD, BFG makes some great tires...
spacers will make the vehicle take more room to turn a full circle.
but if you want equal width. then its 1.5" per side wider.
5333768555
It looks really good! I believe the rim is a 15x8 and they are right at the fender line. And I think I am not gonna bother with spacers on the back end as it looks ok. It doesn't look monstrous but it finally looks proportioned...here is a quick photo.
http://www.flickr.com/photos/57995432@N07/5333768555/
ordered pro comp steel brake lines as well...the tires add just enough to make my eyes get wide hitting the brakes so should have those installed next week.
i ran those on my jeep wrangler when i had it. LOVED those things. drove great on the highway up and down from VA to VT, quiet, smooth. and while i never did any serious wheeling, i certainly never got stuck. Bout the only time they let me down was when i lost control in a blizzard up in VT. but to be fair, i was in 2WD when it happened. jeep went sideways, and rolled a few times. no more jeep.... but i wound up with a Blazer instead :woot:
pro comp that bad? Ima look at the ORD ones...I have not been on much at all so have lost most my links to the CK5 approved dealers.
hrm...well....ORD has the sway bar disconnect kit too that I have been thinking on...so yeah...the brake lines are the same price as the procomp.
