Busted Zerk
BGKYK5
3/4 ton status
on the crapper...
What is the best way to extract a busted zerk fitting? This one is in the lower kingpin on my D60 and it is broken off below the surface. I was thinking of running a drill bit down the hole from the opposite end in hopes it would break free and spin out. I don't want to damage the threads though.
definitely try the easy-out first. if that does not work, then drill.
how did you break the zerk?
easy out usually works fine, i break zerks on my equipement constantly so i have had to remove lots and lots of broken ones.
Thanks, I'll see if I can round up an easy out.
The zerk was already broken when I bought the D60.
it's in a vulnerable spot. Some people have welded a guard onto the bottom cap to protect it.
small torx bit socket works great for me. Tap it into the hole in the zerk and turn it out.
I should have thought of that. :doah:
I picked up a set of bolt extractors at lunch and it came right out.
I already had a set of torx bits though. :rolleyes:
