red EOD
red EOD submitted a new Build:
C3500HD tow rig
Read more about this build here...
C3500HD tow rig
Stumbled across this truck on the local ads and couldn't pass it up. 1995 C3500HD with 6.5 diesel/NV4500. Pretty low miles at a little over 141k, had been used as a electricians truck. New batts and it fired up, mostly good on the test drive. ABS light on, constant clicking noise from the area of the HVAC box, HVAC fan only works on high, cracked windshield, 3rd syncro sucks (grinds), exhaust cut off behind the cab.
Just a few minor problems and in need of a service. Picked up the truck to become the primary tow rig turning the 82 crew cab into the offroad toy. So the service bed is likely coming off and a flatbed will replace it. Or maybe chop down the rear 4 boxes so the gooseneck can be attached. Goals for the bed are:
Gooseneck hitch
Gin poles
Enough storage for roadside tools, not much else
Has the 11ft ish bed length. 65mph cruising speed at 2600rpm. Might step up to 245/75/19.5 tires to get cruising speed up to 70mph.
View attachment 321056 View attachment 321057
