Caddy spy shot UPDATE 10/24/04
cybrfire
1 ton status
Iowa
Might shift it back about another half inch but up down ways she's good to go.
Edit: I did shift it back but more like a whole inch. Snorkle tubes and some other details up front yet.
Re: Caddy spy shot
[ QUOTE ]
beautiful, when do you think you'll get to drive it?
[/ QUOTE ]
Father's day!
Re: Caddy spy shot
aw come on, you cant be serious! /forums/images/graemlins/thinking.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/screwy.gif
Re: Caddy spy shot
[ QUOTE ]
[/ QUOTE ]
That's the target date. I have lots to do yet. Should make it though. Don't know about the other two that are aiming for that date though. Maybe they will chime in.
Re: Caddy spy shot
8 months from now, dang, you must have a lot to do! /forums/images/graemlins/thumb.gif
Re: Caddy spy shot
Finish mounting engine
Rebuild engine
cage
seats
shocks
trans
xfer
drive shafts(got a freebie coming from HAD)
most of the electrical
spare tire mount
air tank for OBA
OBW
Armor
winch
brake lines
fuel lines
radiator and elec fans and plumbing it from one end to the other.
then the whole slew of little things that ties it all together.
Maybe not that much but that list sure looks shorter than I think it should
Re: Caddy spy shot
that looks familiar, put a bfh against the firewall & push it on back
lookin good, i am aiming for christmas
Re: Caddy spy shot
mine was almost against the firewall, & w/ the doubler i wound up w/ equal length d-shafts, which i thought was cool. only need one trail spare.
Re: Caddy spy shot
Mine is almost contactin the fire wall on the driverside corner. Did yours fit tight there. I already trimmed a corner of the bracketry that holds the brake booster and such to the fire wall. The lip that sticks out on the fire wall has been hammered back but there's plenty of room there yet. Just close by the head in that one corner. Otherwise I could shove it back at least 1.5" yet.
Re: Caddy spy shot
Whats up with the nippco /forums/images/graemlins/confused.gif you're not cold are ya /forums/images/graemlins/whistling.gif
[ QUOTE ]
Father's day!
[/ QUOTE ] He didn't say what year/forums/images/graemlins/deal.gif
My to do list
finish cutting fenders
remove rocker and install sq. tube slider ( one side is done)
then take the body off again
remove and rebuild the 205/203 grear box
remove and rebuild the th350 add reverse manual v/b
remove the engine and check the main and rod bearings
clean and paint and install the 4 above items
build trans tcase cross members and flat belly pan
HAD drive shaft x 2 1410 yokes
install DEtroit in the 14b
make custom stainless radiator tubing/hoses
wire the engine
exhaust
anti-rap bar
turn the 57's around to help departure angle
shocks
cage
seats
bumpers front and rear
flat bed
bump stops
OBA
spair tire mount
electric fan
winch??? maybe
hydro-assist
/forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
Re: Caddy spy shot
Anytime you want an extra hand stomper gimme a call /forums/images/graemlins/waytogo.gif if i dont have class ill come help out in whatever way I can, still learning alot but i could help with the prep and paint work.
Re: Caddy spy shot
[ QUOTE ]
[ QUOTE ]
Father's day!
[/ QUOTE ]
Nope, not cold but if it wasn't under the truck it'd be totally buried in one of the other various storage locations. Just thinking ahead.
Definitely, if you get some stuff lined up to do I could buzz over there some weekend to do some wrenching as well. Make it a wrenching party. You buy the beer! Hell will just crank it up and keep going until the beer is gone or we pass out.
Re: Caddy spy shot
[ QUOTE ]
[/ QUOTE ]
You two have me beat. Time for the SPRINT to the finish. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/hack.gif
