41565chevelle
speakez6, nice job! Looks like it will all work out real well and also keep the DMV off your a**. Give an update when its all done.
Yeah, common theme. I just installed the TBI back on mine and want to go to headers and seep set up and loose the air pump. It would smog as a 1991 which did not have the air nonsense. Good luck with the lift.
From what I understand, and know from past experiences, yes. I had a 91 c1500 with the serp system and without an air pump. The exhaust manifolds were bare without plugs where the air ports go. So now I am looking for those exhaust manifolds or CARB headers. I can then put on the serp system and swap the alternator and A/C compressor sides. I loose the air pump but can put in a pulley for the deleted air pump. Some of the serp systems do not have the provision for the pump, but the older ones do since Chevy had a bunch to get rid of.
The kicker is the computer. I have a computer for a California 5.7l from a 1991. Now the truck gets smog checked to the newer year. Now, since you did all that with the TBI, you are burning super clean, considering you have the fancy exhaust and all. I think you could go without the air pump, plug the ports and do the serp system. All you tell the shop is you upgraded to a 1991 Chevy 5.7l engine. Its all the same, just w/o the air pump.
I have the same identical system you have in your photos.
I had my carb (PO) go to crap on me. I had to do an adapter plate for the TBI to the Edelbrock intake. Then the TBI hit the EGR which had been smashed underneath and group to make room for the carb (PO). I added the spacer to lift the TBI, which now pushed the linkage up almost 2" and back 1.5". Had to do a new distributor, cap, rotor, wires, EGR, factory coil as well as modify every vacuum hose in there. I then had to do a new in tank fuel pump, inline fuel filter and then line from there to the TBI. I had to get a bunch of parts for Pick a Part to make it all work. Including the air pump hose and air filter housing like yours.
Been busy and had to have the shop do a bunch of the work due a lot of electrical stuff I suck at.
I will say this about the thorley ca legal system it sucks as far as some of the bolt locations there isn't enough room for a box end wrench and I just spent the last 3 hours cutting a bolt off because they didn't bother to check if a wrench would fit.. Arghhhh glad to be rid of this!
My 1992 doesn't have an air pump or air injection. It's a ca truck also 7200gvw
If you want I can take pics for your refrence?
