A wheel chock will work for that.
Martin
Martin
Locking your tires up is not the test of good brakes. Good brakes should be able to take your tires right before the point of locking up and hold them there.
With these old rigs it is the driver that gets you there. Knowing how much brake can be applied before the tires lock up.
The technical term or possibly what we used to call it is threshold braking learning your brakes well enough to prevent lockup but have maximum braking freaking hard to do right
I want to be at Bens house when he burns out, and all of this trick stuff is for sale at 10 cents on the dollar.
Soory Ben. Could not help myself.
this was just a random thought that I don't think has been covered.Is that the job of the calipers, or of a proportioning valve of some sorts to get that?
It takes the whole system (including the driver). The dual, quad, or 6 piston calipers do more than just increase clamping force. They spread the load more evenly across the pads. Look at how little surface contact the piston actually has with the pads on our stock calipers. Compare that to these Willwood calipers. I would bet that they release more completely as well so you don't have as much static drag on the brakes when the pedal is not pressed.
.... It seems that there would be SOME where.... I have something new to search the interwebs for
mine needs a total redo.... im in the process of getting parts now. they suck..... but I figured if im gonna buy the parts... why not look for better stock bolt in's![]()
