I'm working on a 355 that I'd built back in highschool, but could never quite get to run correctly. I suspected a wiped camshaft lobe (didn't run right after a new cam was installed) and pulled it all apart to inspect it. Once I checked all my valve lifts, I discovered that everything was perfectly within spec, and that all the lifters looked beautiful on their wear surfaces.
Since the next logical thing that came to mind was valve timing, I borrowed a degree wheel to check the intake centerline on the camshaft. Following the steps laid out on a hot rod engine article I found online, I discovered that my intake centerline is at 113.75 degrees, whereas the cam specs call for 106 degrees (a difference of 7.75 degrees).
I know that you can purchase timing chains with different keyways machined into them to advance or retard the cam timing by 5 degrees, but I was wondering if there was a better way to adjust it so it is more precise, or if that extra 2.75 degrees of difference would be significant to the operation of the engine.
Can a guy combine one of those multiple keyed timing chains with a camshaft gear shim? Do they make shims as small as 3 degrees?
Thanks for any help you guys can offer!
BTW engine specs for you:
350 bored .020 over with factory cc dished pistons (freshly built, less than 10 000miles)
Comp Cams Extreme energy XE262H (218 in, 224 ex @ .050, .462 in, .0469 ex valve lift, LSA 110 degrees, 1300-5600 rpm)
Vortec heads with screw in studs and aftermarket valve springs as reccomended by Comp Cams
Vortec Q-jet intake, and a Q-jet carb
Symptoms included a poorly running engine that popped through the intake and exhaust with severe idle problems, but decent higher end performance. It never made any knocking or ticking noises, though ignition timing had to be set close to 20 degrees BTDC to make the engine idle decently.
The carb needs tuning (originally from a 425 olds) and I have not messed with the timing curve any, but I knew that the problem was more than the carb, as the engine acted up exactly the same with two seperate sets of heads, two carbs & intakes, along with a TPI setup.
