Can anyone i.d. this head casting?
handloader90
Building!
Colorado
Looked through my books and on the interwebs and have come up short handed.
This is the passenger head and it only has one bolt hole in it to the far left.
Pulling a cover is a sure bet. Looks like a mid to late 70s GM corporate blue, likely a 883 head:
76cc chamber 1.94 intake smog head
The engine is definitely blue in color.
I'm guessing those aren't great heads due to the word smog being in there.
Oops 882 is the number. Guess we’ll see
If they are not, I’d start to wonder if some parts got moved
The head on the driver side has 3 bolt holes in it. I didn't look at the casting on that one but I thought the bolt holes in the head were supposed to mirror eachother.
the holes on the back side of the opposite head will mirror the front of that one...that way it didin't matter which side the head got put on.
this is what the other side should look like:
That's just a standard 882. Some had small valves and some had bigger. No larger than 1.94s.
The 882s were said to be 76cc. But that could vary. Recently i had a set of 882s that were 80cc.
They work. Not the best but they do work.
TBX was also a 1979 350 used in c/k 10/20 trucks.
Did a vin break down of C9J141597 and came up with
C = chevy truck
9 = 1979
J = Janesville
141597 production number
V1027TBX engine number decodes as
V = Flint (engine plant)
1027 = (mmdd) October 27
THX = 350ci 79 c10 k10 c20 k20
Since the heads are blue I'd say its the '79 engine as noted above..
GM started painting engines blue around 1976 or so..
It sucks they use the same engine codes on multiple years often--we ran into grief at the junkyard often due to this--sell someone a "350" going be the car it came from,and the engine code in the Hollander Interchange Manual,then have it come back later after the customer took it apart to rebuild,and found it was a 305 from some other year,that had the same code suffix..
I no longer have access to those manuals,I can only go by what listings I find online,and assume they are correct..
I suppose you could ID the engine's age by the "clock" on the casting on the bell housing area,that would pin down which one of the two years it was..
As for the compression ratios,yes,some special optioned engines like the 327 noted above and some BBC did have higher compression,but for normal everyday passenger use engines, the compression peaked in 1970 for most all engines,not only GM but many other brands...after that it was all downhill..
I read often that certain heads are "noted for cracking"--its funny,but I spent 22 years in auto parts stores,two of them had machine shops,and it was pretty unusual to see a cracked head in my experience ,the few ones I saw came off engines that were overheated badly or used in 1/4 mile drag cars mostly..
We did see many with surface cracks in between the valves,but unless they went all the way into the water jacket,they were considered "useable",and we did valve jobs on them and customers ran them without any problems..maybe they crack more in other parts of the country where it gets much hotter and vehicles work harder in higher altitudes ?..more blocks and heads crack here due to freezing when people skimp on adding anti-freeze than other reasons probably..
I googled the casting number on these heads and started reading threads on forums here and there about how a guy may have traded or bought a set of these heads. The responses I paid attention to were the ones stating that if you don't overheat the engine then the heads will be fine and a few people stated that if the heads aren't cracked by this point then they've probably seen enough heat cycles to not worry yourself about it.
