If you're trying to take out excessive caster you could also try spacing DOWN the front spring hangers you built....
That would have the same effect as a shim (depending on how THICK of a spacer would be required to get you into the correct range)
I'm not sure which would be the easier way to test your theory....I apologize for not reading the whole thread. Some of those guys (most notably Greg72) sure do write a LOT to answer a simple question!!
Originaly thats what i thought was positive/ negative but when i was looking at gregs post it through me off... oh well
