I had the same vibration around 45ish and up. Mostly when you let off the gas. Orignally thought it was the rear output bearing of the tc, changed that and notice a little slop in the slip on the driveshaft. Bearing didnt change anything so I swapped a driveshaft in that my brother had with a tight slip and problem went away.
Cause of my lift the splines are exposed a bit so Im gonna grease the slip joint every couple hundred miles or so to try keep the dirt and crap out. Hopefully this will extend its life.
Rebil
Rebil
