UP K5er
Registered Member
Can I install a c/v joint from a front driveshaft on the rear driveshaft to make it longer and get rid of vibes? This is ASSUMING that the length will be correct after the swap. Has anyone done this?
I'm cheap and don't want to invest in a "high angle" c/v driveshaft at this point. I plan to convert to a 241 fixed yolk in the future. 87 K5 shackle flip + 2" springs. NP208 with slip yolk and stock driveshaft.
. I need to fininsh the rest of the 6" tuff country springs this weekend too
. Never enough time to fininsh my projects. Thanks for the info.
I'm going from a poor memory...thought a c/v just has 2 standard u-joints. I'm sure I will be corrected...
I was hoping to save 400 bucks. guess I'll have to save up for a new driveshaft. I had to try... Thanks for your help.
