Can I put 38 inch Boggers on my ride?
78 GMC Jimmy
Seattle, WA
So I have a 78 GMC Jimmy (Chevy Blazer).
I currently have fairly bald 37x12.5x17 A/T tires that were rubbing a bit while turning the wheel while changing angles. Like going from flat to steep uphill road with the wheels turned, it would rub. I beat the shhhhh-it out of the fenders with a sledge hammer, and now they don't rub anymore.
I don't know what lift I have. 4 inch maybe?
So I'm thinking about buying some 38x12.50x16.5 Brand new Boggers, with 8 lug rims. All brand new for under a G.
Thoughts?
Should I plan on needing more lift? Sand paper to the fenders? Jack hammer to the fenders?
Whatchall think?
I bet they’ll rub, a lot. Both tires might be 12.50 wide but the lugs on the Boggers will almost certainly stick out further than your existing tires.
@Fastereddie is good at it, did a great job on my 77. He's got 40s and I run 37s with link kit that stuffs up in there with no rubbing. I would think 38s would fit after trimming. Cut off wheel or air saw works well. Hopefully you can see where mine was trimmed.
Going to have to trim more, I went to 38's from 37's and had to cut quite a bit, I also moved the axle forward an inch or inch and a half and that helped with keeping them off the firewall.
Whats the fix ? More sledge hammer'n? More lift?
Yes to any of those. Lift / cut / hammer / remove the fenders, it's really whatever you're willing to do to clear fit the tires.
Narrow wheels and more inward offset will fit more tire for a given lift than wider wheels that push the tire outward.
Go measure your 37's. Most are "radial-sized", meaning it's probably 35.5-36" diameter. The boggers will be pretty close to rated size.
Angle grinder is your friend. Mine is a combo, cut lift. When you think you have enough park it at an angle on a hill with wheels turned both ways and check then take off more for hard compression. You can also look at a zero rate if needed for a bit of lift and locating the axle to rear if needed. This on 37's but it flexes pretty well.
Zero Rate lift - would one of the really be safe in the front? Can you stack two of them in there? I bet 2 more inches in the front would be enough for the 38's, no?
Zero rate you can also move the front axle forward; then a slightly longer shackle. or bite the bullet and get a bigger lift. or do both.
I wouldn't stack them anywhere. You can use a zero rate up front but new springs would be preferable or extended shackles in my opinion.
Can i just throw some longer shackles on front and rear to get another 3" of lift?
Would that work?
That mark looks like your axle is sliding on the spring, most likely a broken leaf spring center pin. FIX THAT SOON!
Since shackles are only on one end of the spring using longer shackles only nets 1/2 of the additional length. In order to achieve 3” of lift via a shackle it would need to be 6” longer than stock or approximately 10” long, using a shackle more than 1” longer than stock will create all kinds of alignment (caster) problems.
And pinion angle for sure!
If I get that ... Zero Rate thingy for for the front and the rear, will that be a good small lift, and also address this sliding axle thing? Do those kits come with a replacement.... Center pin?
Actually, yes. The Zero Rate will get you 1” of lift and in addition to being clamped in place by the u-bolts they attach to the springs with the center pin.
