Can I use this water separator?
85 Jimmy
Sheepdog
Gulfcoast
I need a water separator for my compressor and found a couple of these at work. I'm curios if they'll work for me if I get some reducers. Also, what's the second reservoir for? It just has a rubber tube that runs from the housing to the bottom of it. It's a Legris brand, I've never heard of them and can't find anything other than they sell push lock fittings on the Internet.
I just want to keep the water out of my tools and to be able to paint without getting water in the paint. When I run my die grinder for a while it starts dripping water out of it.
if there is just a tube running to the bottom of the housing I'm not sure it will be too effective...generally the water has to have a place to condense, like a centrifuge action that will give the water something to stick to and condense enough to drop out of the air flow.
Look up a few air/moisture separators and check out their construction and compare your unit to them.
I'll have to take a picture with the reservoirs removed. The left side, where the air goes in first, has a dealio that comes down and is has little fins in it. The reservoir on the right that's the second one just has a little house that goes down into the bowl.
The one side (with the psi gauge) is an air filter and regulator right?
Here it is without the bowls on. From my google image search it looks like a standard oil/water separator.
Pretty sure that's your basic FRL, filter, regulator, lubricator. Great for air tools proper (grinder, drill), wherein you filter out the dust and water from the compressor, and put in a smidge of oil for the tool.
Not so great for painting where you don't want oil in the mix. But then you just don't use the lubricator.
-- A
