Can someone check if this Hydro diagram is correct?
K5Nate
San Jose, California
Ok so Ive gone with Vanco Hydroboost unit and PSC ram assist for my build. Neither have provided me with routing instruction so I have put my set-up together to the best of my knowledge using what technical info and schematics I could gather, the only issue I had was no one really has a diagram for a GM hydro boost with a remote reservoir which includes 2 return ports. I know someone has this same set-up, Check out my beautiful diagram workmanship and let me know if I have everything hooked up correctly.
Keep in mind I have labled the ports on the ram and steering gear just as they are on my rig the ram in the pic would be facing you if you were to look directly at the truck. The steering gear is as it mounts on the frame.
The factory hydroboost setup has both returns going directly to the pump, not the reservoir. Not sure how much it really matters, but the pump is lower than the reservoir and thus would be easier to pump the fluid back to the pump????
The PSC Pump I have only has 1 suction (from res.) and 1 out port, which form what I can gather goes to the hydro first.
