Well Canmore, the way i can tell that it maintains oil pressure better is by the fact that the light no longer comes on at hot idle, as i stated above in my original post that you quoted parts of. Perhaps you should reread it? Also, i did not mention the fact that i did the same thing with a freshly overhauled 350ci in a Blazer, while breaking the engine in on conventional 10w40 (synthetic is so slippery that pro's will tell you to NEVER break in a engine on synthetic, that says something for it right there to me) i saw hot idle oil pressure's in the 7-15 psi range, after it was broke in i changed to Mobil 1 15w50 based on my experiance with the GF's truck and the hot idle oil pressure went to 20-30 psi (high volume/high pressure Melling pump )
As for the cooler part, you are correct, i have no temp gauge and in fact my basis for the synthetic running cooler is in a rear axle and not in a engine, however i would certianly think that it would carry over to some degree (the diff cover on my 14bff in my 74' k20 with 4:11 gears and 36" TSL radials was too hot to touch after driving for 45 min's straight on the turnpike at 70 mph with conventional 75w90 valvoline in it, now with synthetic 75w90 amsoil in it you can hold your hand on the diff cover after exactly the same conditions, still hot but definitly tolerable)
i have also placed a qt of 15w50 mobil and a qt of pennzoil 10w40 out in the snow over night (approx. 0-15 degrees) the next morning i picked them up and shook them, then poured them out, the 10w40 conv. was like friggin' STP oil treatment it was so thick, the mobil however poured and shook just like it did at 80 degrees. Synthetic, being manmade, just doesn't react to temp. changes on either end of the spectrum like natural oils do.
One last pesional experiance;
My boss at NAPA once was gonna junk a S-10 p/u because the 4.3l was so worn out and had such bad bearing clearances (but it didn't knock yet) that the oil pressure dropped low enough to allow the oil pressure switch to kick the fuel pump off.
Guess what?
Yep, 15w50 mobil 1 synthetic, ran that truck till the sticker ran out and it NEVER shut off again
scientific, no
Do i honestly beleive in it, yes
and i feel that even if i'm wrong, it will be no worse for any metal part then any good conventional oil.
therefore, i got nothing to lose but a few extra dollars
I don't really care who runs it or who doesn't, that choice is yours, I however will, just thought i would share my experiance's with it /forums/images/graemlins/waytogo.gif
