Working on Craig's rig (priceygmc on here)
Wishbone rear with almost parallel trailing arms.
Delron mounts at frame, heims at the axle.
Not too worried about the roll factors, as he said he will probably get a fancy swaybar.
I think everything looks good. Pinion angle matches the tcase at static. 5.5*
At bump of 10" it will be darn close to perfectly horizontal, and at 10" droop it is at 10* up. I seemed to really like these results. Axle will only move back 1.125" under 10" of up travel.
The lower links are set and tacked in and I don't want to move them. So if you guys think something needs changed, I have only cut one piece for the wishbone, and its not dependent on any measurements.
sorry if you've seen these pics 80 times by now.
1-1/4" bolt
I will be making a jig on a sheet of plywood for the final setup of the Wishbone. This was just to get an idea.
1-1/4" bolt
