can't find these tires
sfos
Registered Member
nc
Gona be the owner of the k5 soon and it needs a new tire. The problem is I can't find the tires on it anywhere. They are 15/38.5/16.5 ground hawgs which I'm guessing are discontinued. Anyone know where I can get one? Also if I can't find one I'm probably gona go the military tire routs for now. Can you mount the military tires on a 1 piece wheel or does it have to he a 2 piece? Thanks
ground hawgs are disc now and no longer made .
keep a eye out on craigslist and 4x4 forums for used .
the 37" hummer tires will fit fine on 16.5 reg rims . I had a set on 9.75 wide rims and would not recommend them on anything wider of a rim .
and the hummer tires are not the best in the mud just a fyi .
The military tires are a pain to mount on wide wheels, they are much easier to get mounted on stock wheels, plus the GM wheels will have a safety bead, unlike aftermarket wheels.
Martin
Ground Hawgs have been discontinued for at least 3-4 years now. Considering the newest tires are at least 3-4 years keep in mind that ones popping up for sale could be really old. Craigslist or other off-road forums would be your best bet to find one, but good luck just finding one.
Crappy part is I don't have much to trade anymore!!!! Wanna SAS my 88 and gonna need bigger sneakers than the 35s on it now...
