Never mind… I think I found my answers.
Charlie
Charlie
OK, I missed this earlier.I did disconnect from the dist. and plug the carb port when I took my reading.
Yeah, that's what I was saying. Timing was measured at idle.If you’re hooked to manifold then you’ll be advancing the timing at idle, ported won’t advance the timing until the throttle is opened but it happens as soon as the throttle is touched.
