77scottsdale
Registered Member
i got a 92 350 30 over all stock with a performer intake and a 600cfm edelbrock carb with spring loaded needle and seats and a summit hei performance kit with a msd 6al and it likes to load up if you dont stay in the throttle when going up hills and if you are in 2wd high punch it and let off it will cut off
my hei does have an adjustable vacuum advance
another thing is i have a milling electric fuel pump at 5-7psi, i set the carb with a vacuum guage to about 19psi and it still has a rich smell to it no matter what i do
Long lesson to learn to tee into a line when checking for leaks. Look down the carb at idle to see if its pushing fuel.
