Ok for all of you who are complaining about small engines with carbs:
I work at a lawn mower repair shop. Believe me, FI is a VERY long way off from getting on lawn mowers. The smallest engine I know of that has EFI is some 800cc ATV. EFI on a lawnmower would make a normally $250 mower cost over $1000. And at that point your carbed $250 lawn mower will lost a long time with the propper maintainence and even if it dies, buy a new one or two and even still that would be cheaper that buying one EFI mower. They make mowers today that are very cheap and very easily repaced.
Also I don't see why EFI is REALLY needed on a mower. Carbs do just fine as far as performance. As far as reliability, I've seen engines run perfectly fine off a totally gunked clogged up carb and others that won't run with a spec of dirt in them.
As far as bad gas goes - EFI or carb will still make the mower run poorly or erraticly. By far this is the most common problem I see. People let the mower sit over the winter and wonder why it won't start in the spring. Gas goes bad in about 3 months or so and even worse, I find a lot of water in gas tanks and/or in the bowl of the carb.
Anyone else has any questions about anything lawnmower related, I can answer them.
