ORD Engine Cross Member
IRIECHEFDEEZY
Atlanta
Has anyone installed the Off Road Design engine cross member in a 72 Blazer? I'm working on one now and will eventually go with a BBC engine and am wondering where the new holes need to be drilled into the frame. i have the later model engine "saddles" and they also need holes drilled into the top of the frame. before i go turning the frame into Swiss cheese, I'm wondering who else has done this and do you have any guidance and or measurements to get the valve covers off the firewall.
I can't help you on the valve covers. I had to drill one extra hole on top of the frame on each side. On mine I had to trim the angled part that fit into the c channel of the frame to fit between the upper part of the frame and the lower. But that may have been a "jimmy" thing.
Here is a link from ORD's website with some pics if you haven't seen it.
In my build thread page 2 post 23 starts my saga on.putting in the crossmember yours should go much smoother.
Get a 90 degree angle drill tool it was very handy.
Thank for all of the help. I’ve also had to trim the corners that went into the frame. I’ll take a look at your thread and try to get mine installed.
I installed mine in my 73.
It took a bunch of prying, alignment bars, drill and many drill bits to get it installed.
Not the fault of the cross-member. Which was perfect. The poor frame was bent and twisted. Only two of the holes lined up. The rest needed pulling, prying, and drilling.
Thank you. I’m prying and pounding and about to start drilling. I think I’ve got it aligned as much as I can. I can only get the 2 front holes to line up with the 73-87,89 saddles. No other holes line up. I’m going to try a few other holes and see what lines up the best. It’s still a little off.
Trying to load pics but they are too large and I don’t know how to make smaller.
Check your frame squareness
If it's good, just drill the rest of the holes.
If it's not squared, try to pull it to straighten it before you bolt this up.
Simple trick is open them in "Paint" and click on "File", then "resize". enter 50 in the first box (that says percentage), then hit OK. Do it twice and your photo will fit perfectly.
