So does that mean that you didn't replace the heads to fix the oil consumption problem? You had to get a full rebuild? What's the scoop there? I was curious since that thread died, it's still out there...
As for the carb, you have to decide, a double pumper will certainly have more throttle response and can be more finely tuned for power, but the qjet will probably get better gas mileage and will run better on hills at angles. It all depends on what you prefer, it's a tradeoff.
I am a Holley man because I like power and tuneability, but I do enough wheeling I couldn't deal with the engine dying on steep hills when I was trying to maneuver, so I ended up getting the FAST EZ-EFI, it bolts right on your carbed intake and it works awesome, I don't want to go back to a carb. I still have a carb on my street/strip car and I get tired of getting fuel on my hands and dumping it everywhere when I need to jet up for the cold weather, etc. Which it will run fine without jetting up but when you are trying to tune for ET it is much easier sitting in the cab with a computer or handheld.
I will say one thing, as much I as I love Holleys, do not put a truck avenger on a 500 hp Big block, I tried it with a 770TA on my truck, and tuned the crap out of it, jets, cams, squirters, acc pumps, etc. The problem is, in designing the TA carb they eliminated the high speed air bleeds to keep the circuit from dumping fuel in at angles. What this does is change the shape of the fuel curve, so pretty much the carb will always be lean at low RPM and rich at high RPM. After a lot of tuning, my truck ran OK, but didn't run crisp at RPM and didn't have the power it should, it would idle on a hill though! Luckily Holley has excellent customer service, they traded my my TA for a reman Street avender and the truck ran a ton better, I still tuned it a little better yet, but it was a night and day difference. However, then the truck would die on steep hills and I would have to keep revving it up to keep it running or it would go pig rich and die.
With my FAST system, it has the power and response of a double pumper, the fuel efficiency of the qjet, and it doesn't care what angle it's at or how bumpy it is, it runs good all the time.
Theres my info, hopefully it helps you decide.
