I was having heat soak/percolation issues with my carburetor running 195+ degrees while trail crawling and after hot soak. A 4-hole 1/2" spacer off ebay did the trick.
FYI, I used to run a phenolic spacer on my Mopar 440 many years ago and "forgot" what a difference it made. Of note, Chevy manifolds tend to run a lot hotter due to coolant routing and direct exposure to valley oil splash. Good argument for the Edelbrock air gap series I suppose.
Oh yeah, BTW the PO neglected to install the correct adapter plate on the Performer 2.0 manifold so there was a pesky manifold leak below the carb when it heated up.
http://www.edelbrock.com/automotive_new/mc/install_items/adapters_spacers.shtml
