Cat exploded, motor is alive, what next
So with the Hedman 69830's I would have to get reducers from the 3" outlet to 2.5" pipe for the Y, then 3" after the Y pipe.
2.25" Appears to be stock for the Y. I just measured it. You don't want the Y to be too big or you will lose a lot of your bottom end, and with a 305, you need all you can get.
EDIT: Use this for the merge. http://store.summitracing.com/partdetail.asp?autofilter=1&part=FLO-Y250300&N=700+115&autoview=sku
