That is my theory,seems cam makers do not harden the lobes correctly ,at least one lobe always goes bad on a chevy cam,on the OEM ones,the 307 and 305 engines were well known "cam eaters"..
My friend recently installed a brand new Edelbrock cam ,lifters,and valve springs on a 1969 Chevelle's original 327 ,which had the #1 cylinder push rod on the exhaust valve bend for no real reason,and another lifter was all concaved,but we forget which lobe it was on..anyway,the #1 exhaust valve was not opening much,so the exhaust escaped through the intake valve next time it opened,causing the classic "needs a cam" chevy gargle/backfire through the carb...
So the owner buys the parts,and my friend installs them,along with new valve stem seals..old ones were brittle if still there at all,so they were due--engine has 80K original miles on it,car is really nice too..was well cared for..
After he got it installed and did the break in correctly using the provided moly lube and fresh oil,the car once again ran sweet--there was debate about how many turns to tighten the rocker arms after zero lash--my friend decided to use the Motors manual specs of 1-1/2 turns,another "expert" who has installed many hi-lif cams said "I'd only go 1/2 a turn..anyway,it ran nicely,so my friend did not think it matered much..
About a week later,it came back,backfiring again!..had one bent pusrod in a different cylinder,#7 this time--and after replacing it my friend noticed that rocker arm had to be tightened a lot more than the others to get the valves adjusted,and he said "it CANT be the cam lobe worn already,can it?..I said "possibly,either that or the lifter base is wearing down (doubtfull,without taking the lobe with it!)--or the rocker arm stud is pulling out of the head maybe..(but appears not to be!)..
I'm betting they hardenen 15 out of the 16 lobes "right",and one gets a "so-so" hardening..that coupled with this new "low zinc" oil,seems to be causing a ot of grief among flat tappet engine owners..By the way,newer diesel oil is also "low zinc" to be able o be used in 2007 & up diesels,so unless your buying "old stock" somewhere,using diesel rated oil offers no real advantage I'm told,and can loosen sludge up in old hi-mileage engines and wipe cams and other parts out too..
Looks like they are going to kill off the "clunkers" one way or another..what do we have to do now,put roller lifter cams in everything??..
