improper break in is likely. also for any flat tappet came engine i use Joe Gibbs break in oil for the first 3000 miles then i use their Hot Rod oil, it has high zinc rating, it says its not for street use..but oh well
I know flattened cams have more to do with the manufactuing and hardening process then anything.
To my experience Zinc is the key. Not saying your wrong, but everytime I have seen a flat tappet cam failure it was due to using oils, synthetic or not, that did not have the proper amount of zinc. I used to use Valvolines Racing oils but they lowered the amount of zinc in it recently. once that change was made 5 of the 6 engines i built flattened out the cam lobes on the dyno. I talked to the local drag racing team and they turned me on to the joe gibbs stuff. Ever since I started using Joe Gibbs I have yet to flatten a cam on the dyno nor have I had any customers flatten cams down the road. now i wont warrenty a engine if they use anything else other than joe gibbs. I had a customer with a 496 big block making about 650hp. i broke it in with joe gibbs and did the first two oil changes with it. after that i didnt see him for a while. turns out he put some regular oil in the engine and it ate up his cam. the solution to all this is to run a roller cam...but who wants to pay $500-700 for some lifters?! not many of my customers do.
Oil - my favorite subject..
Sticking with a high zinc race - only oil for break in is key..of course, if you don't have cats to worry about, and can afford 10 + dollars per quart, keep using it afterwards.
As for newer truck and passenger car oils being "better" than previous versions, that's just marketing BS.. the oil manufacturers are told how to formulate their oils, and then it's up to the marketing departments to put a happy face on it. they can't reduce wear, or control acids like they used to.
When discussing oils, it helps to bear several things in mind:
1) Any oil can be marketed as "synthetic", regardless of ingredients. google "castrol lawsuit", and you'll see.
2) All oils are processed petroleum hydrocarbons. conventional oils are just "less processed" than the more "highly processed" synthetic oils.
The actual definition of a synthetic oil used to mean a PAO oil, processed to the point where all of the molecules are the same size. that's where synthetics really shined,as they had better hot & cold flow properties due to this.
Problem is, PAO's are expensive, so they get blended with conventional mineral oil and solvents to bring the cost down.. the more expensive oils have detergents, but the inc / phosphorus additive levels are mandated by law, and have nothing to do with if the oil is marketed as a synthetic or not.
as for a zinc additive being compatible, if you are going to do that, it's better to use a non PAO oil, as they don't hold onto additives very well under heat.. back when mobil one was actually a PAO synthetic, you could scrape the depleted additives out of the oil pan. find a cheap group II mineral oil, and have at it.
If cost is an issue, and emissions equipment isn't just run a diesel oil, and dump it every 3,000 miles.. if you want to go further, then have the oil analyzed.just looking at the shiny parts doesn't really tell the story.
There are no real laws or regulations in Mexico. Maybe I should swing down and pick up a few case of old school oil!
