The fact that big ass wide tires dont help like people think they do. Theres two mud scenarios, mud with a solid bottom, mud without. The only time that wider tires help is when you are in mud without a solid bottom and when your in a 4000-55000lb rig it takes some damn big tires to float over the slop with no bottom.
Skinny tires get you down into the mud to the more solid dirt faster.
Personally I believe the only place wide tires prevail is in bottomless snow. Give me skinny meats any other day of the week.
The problem with wide tires is, most people don't have the power to spin them to clean them out in the mud. If I have a choice, I run wider tires and use a lower gear to get the wheel speed up. But I also have a motor that dyno'd at 415hp at the crank. And am building a 454 to replace it.
