Center bolt valve covers Anybody have pictures of inside of tall style?
http://www.speedwaymotors.com/Blumax-Chevy-Aluminum-Roller-Rocker-Arms,6566.html
BLUMAX S/B CHEVY ALUMINUM ROLLER ROCKER ARMS Item # 57533519
The BluMax self aligning, narrow-body aluminum roller are designed to the same high standards as the other other BluMax rockers, but are for use with center bolt valve cover heads.
Features:
  • Self-aligning, no need for push rod plates
  • Designed to give better clearance with center bolt valve covers
  • Ideal for Vortec and other center-bolt heads
Cannot be used on heads that have not had the stock "slotted" push rod hole drilled out to a round hole. Cannot be used with guide plates.
Martin
