Project "RESPAWN" - 1972 K5 Blazer
Cool stuff here!
A person asked at the bottom of the page. Summit "expert" said ~26" and 1.8" ID meant for 1.75" application.
The one you linked looks a lot like the one I currently have. And i hate it. Absolutely most pain in the butt hose to install/remove. That said its theoretically cheaper per foot.
Hmm, I wonder if the new one you ordered can be bent a little, when does yours come in?
Tracking says tomorrow. For my 86 its a straight shot so no need for a bend. Will bend the one coming and let you know. The one I have now like that Dayco has wire reinforcement and might take a bend better.
  • Like
Reactions: CK5
Do you have a local Parker store? They carry fuel rated hose.
  • Like
Reactions: CK5
I got mine from a local hose supplier. Pretty sure I used exhaust pipe to adapt the 1.75 to 2" though.
  • Like
Reactions: CK5
Did it come in?
Hose seems of decent quality but if you are needing a 90° bend I don't think you want this one. Was already starting to kink with a slight bend.
Got everything plumbed in now, next up I have to clean up the area where the tank was just because. I decided to just use all new parts while I was in there, was thinking I would spend around 350.00 to 400.00 bucks total... so 700.00 wasn't too bad. :doah:
Got everything installed today, used RTV to attach tank felt to the crossmembers and tank straps. Looks like I now have 10-12 PSI fuel pressure instead of 8.5 but still has a miss and not as much power as it should. It is now LS ready and my fuel guage is correct at least.
