Wiring for the glow plugs is pretty simple.
There is a cable that runs from a battery source (starter post, firewall junction block, alternator or possibly the battery itself) into a big heavy duty relay, from the relay it comes out into two thick orange wires, at the end of each wire the four fusible links for each bank of glow plugs spliced on.
Depending on the type of relay you have, there may be differences in how it is wired up, but I'm going to assume you are using the earlier style of glow plug relay, which is basically a divorced starter solenoid similar to what earlier Fords use. In that case, your manual glow plug switch inside the dash will run 12 volts out to the relay's "S" terminal.
If you are loosing that much voltage, you've either got a bad set of fusible links, or your relay is in poor shape.
I t would be from the block to the frame right? I dont see one but Im sure what im looking for
I f I remember right shouldnt it be braided steel about an inch in width?
i looked to see if it was hidden even checked the driver side head and nothing there either. Sooo im gonna pick up 2 of them. One to run form there and one from the engine to the frame.
