I do have one vacuum fitting on the carb, right in the front like you said. I can't believe I missed that. However, I only brought enough hose with me to tap into the PCV line, which I did after getting the motor running today.
Went from GREAT day with improved performance to CATASTROPHIC FAILURE....
Story:
Launched around 11am. Tied boat to the side of the dock, where it wouldn't be in the way. Broke out timing light and 14m wrench. Got motor to fire and timed motor at ~10* adv. Set the carb's idle and played with idle mixture screws. Unhooked from dock and set out.
Sped down the lake and got to about 45 according to speedo, felt sluggish like before. Played with timing again and loosened the dual accelerator pumps up for less fuel when stomping on it. Ran better.
Pulled over and cut the PCV line, installed T fitting and put it to dizzy. Played with carb idle settings again. Set out and felt MUCH better, quicker and faster. Hit about 55 in slightly rough water. Before, even on water like glass, it would only get up to about 45. With this carb and dizzy, I'm sure it will hit 60 no problem.
Which isn't that fast, but I can tell there are many other things to address before its right.
Was cruising the lake, careful "The Man" doesn't pull me over for speeding (35mph) and just having some fun. Out of nowhere, while doing about 45, the engine stops and the boat is dead in the water. Opening the hood reveals lots of smoke and oil everywhere. I don't know the extent of the internal damage, but I know the engine ran out of oil and seized. It will not turn over. I had great oil pressure all day, but without hunting the problem down, it seems the remote mount oil filter hose gave out and sprayed oil everywhere. Within seconds I had a big block boat anchor.
I know the crank is wasted for sure and I'm praying that's all it is. I got a quote of $1k to pull the motor and put it back in. I will be fixing the engine.
Wonderful
