Clint's84K5inAZ
Registered Member
I have a new set of superior axles for my 12 bolt and a new set of hub/rotors for my D44 that I'm going to install with my 4:88's. Since I need to buy new wheel studs to put in the axles anyway I was thinking about putting in 1/2" studs to improve strength. Has anyone else done this with their 1/2 ton axles? I also wanted to put wheel spacers on the rear to make it the same width as the front and I don't trust doing this on a 7/16 stud. While I have not lost a wheel due to the 7/16 studs breaking I have had studs break and have seen it happen to other rigs. I have access to required tooling to make this the right way. I am running a detroit in the 12 bolt and a lockrite in the d44 with 35" BFG's, aluminum wheels and stock disc/drum brakes. Any input or advice anyone may have would be helpful.
