smier
A couple of weeks ago I bought a used '06 Chevy Silverado with roughly 56k miles, and after driving it everyday back and forth to work I love it!
HOWEVER.... I started to notice this annoying rattle/clunk that I could feel and hear thru the steering wheel/column sometimes. It was just annoying enough to drive you crazy, and the more I drove the truck, the more I could pick it out. So I started searching the web, and quickly discovered that this is an ongoing problem that almost every one of these trucks develop eventually. Apparently it's a lubrication issue on the intermediate shaft in the steering column, and you can either grease the splines on the shaft, or buy a replacement Intermediate shaft for $50 to $200. Some say the new shafts aren't any better, so I was hesitant to spend much money just yet. I found some write ups on other sites explaining how to disassemble the shaft and reapply grease, but being a lazy SOB, I decided I liked the idea of simply drilling and tapping the intermediate shaft, then installing a grease fitting so I could simply fill the whole thing with grease with my grease gun. It worked like a charm, no more rattle/clunk noise or feel!!! Cost me less than $1 for the grease fitting, took me less than 5 minutes to drill, tap, and install it.
You can see where I installed it, in the upper shaft, just above the 15mm bolt that holds the two shafts together. There is a flat spot on the shaft where I drilled and tapped it. It took 2 separate applications of grease with the grease gun to reach the splines, then I pulled the bolt and actually slid the intermediate shaft in and out of the cowl a few times to make sure it was lubed up really good. Guys on the other sites say when the rattle/ clunk returns, just grease it up again and drive it. I'm not worried about the grease fitting or grease interfering with the columns ability to collapse in a collision, because the ends of the shaft are open, so of anything it will just shoot the grease out of the shaft and collapse like normal. Hope this helps someone else!
