cheap theft prevention..
Does it look like the same bolt pattern on the axle flange/backing plate as the older 14BFFs? I'd love to know if that setup would be a bolt on swap *crosses fingers*.
Instead of a kill switch use a kill button inline with the neutral safety switch. Somewhere hidden, like under the carpet. It'll only start when the button is held down while the key is turned. My buddy had one and forgot to tell me where it was when I was attempting to move his truck to avoid the street sweeper... he got the ticket. An additional kill switch couldn't hurt either.
The only down side to that is if you work on your truck a lot you sometimes need one hand free to do other stuff while cranking the engine over .
