Stephen Carter
Registered Member
So, this weekend was fantastic
As some may have seen I've been hunting for a complete driveshaft for my 87K5. Well I finally found one local, complete with good ujoints! Install it, only to discover everything binds up. 3.08s in the rear and 3.42s in the front. FML.
Anyways when we had my truck up on stands checking ratios, realized a front wheel bearing was toasted.
replaced both bearings (big one and small one). My question pertains to what should have been inside of the hub. In order of appearance (inside to out)
Spindle seal, Big bearing, little bearing, first spindle nut, spindle lock washer, second spindle nut, locking hub internals, snap rings ( one fine for the internals, one large for the internals, and one flat one on the axle shaft), then finally the locking mechanism 'switch'.
First hub nut was torqued to 30ft# (could still spin the brake disc easily by hand), second was torqued to 150ft#. I used the specs I could find with a search.
Just want to make sure that the wheel aint gonna fall off on the way to work in the morning!
