I'm pretty sure you can choose mag,rubber, or PVC inserts somewhere on his
website.. Also it kinda depends on your intended purpose, if your gunna run um on the street and you buy the 12 bolts w 37's, max psi is +/- 50, u don't need a run flat.. 8 bolt max inflation w the 36 RT's is something like 30/40 give or take, I consider those tires total chit, the 37's are way more bang for the buck.. But, if your gunna use them off road mostly or even a combo of on and off you can just get the PVC inserts to retain the bead.. Technically if you really want the run flats than you must really want the security of being able to " run flat" because PVC will retain the bead just the same plus it's a hell
aof a lot lighter from what I understand and if you run tires flat w the insert it chews the hell outta the center of the tire.. This is what I have read on m715 zone (I'm overthere because I have one), pirate 4x4 (unbeleveable wealth of knowlage) and so many H1 and dual rear wheel hub or spacer threads it'll make your head spin + here there's a couple threads about H1s... For 12 bolts shipped anywhere in the lower 48 for a flat rate w tires for that price it's a good deal, look at what everybody else is tryin to get for those rt2's alone...IMO, it's cheap for tires and rims ready to go.. Yeah you need to gear on your rig a little (drw hubs on the d60 and spacers or a wider 14 bolt + thinner spacers) but let's face it we're always messin with our trucks, that's y we're here.... Of course you really gotta like H1s to even b interested in a couple of mods, I am...Most of your questions can b answered on the Trailworthy website....The runflat inserts are not manditory...If you run the strait and narrow and Obey everything Johnny Law tells you than this is kinda a moot point as I believe they are not even DOT approved....
