Checking resistors to see if there good!
backyardbuilt
Olathe, Kansas
I have a multimeter but haven't messed with resistors in so long what do I set it at to check and see if they are good. Thanks!
To check a resistor with a multimeter, one or both legs of the resistive element have to be removed from the circuit. If this isn't done, then other elements of a ckt will throw the reading off in most cases. When checking resistance it doesn't matter which leg you hook to which probe.
